Speedo quit working.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
OK, so I'm not trying to be a selfish ***** and flood GMSB with stuff about my truck, but I have a quick question, because I just wanna know how it works.
Truck is a 89 burb, tbi 350, 700r4.
My 89 no longer has a working speedo as of today, and 4th gear also does no lock up anymore.
I'm gonna take a guess to say the two are related?
I have spare speedo cables, so its not an issue to replace, and magically 4th gear is also acting up at the same time as well as the engine light is now on.
Truck seems to shift totally different now.
So I'm sure more than likely, since the ECM isn't getting readings anymore, it's probably safe to assume the ECM has went into some default transmission setting??
As I said, I'm not asking how to replace the cable, or "whys my speedo not working"
I'm more so interested to know if it's all tied together, just wanting to learn.
Thanks guys as always! !!
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Not real familiar with the later ones - I will guess and say VSS not working.
Does yours have one ? Well, not sure.
Selfish ***** ...
:p J/K !!
Free bump.
Vbb199
Salisbury NC
Vince
Selfish ***** ...
:p J/K !!
Free bump.
Still uses a cable. Its cable driven!!!!!
90 and 91 uses VSS
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Well, hell. Some of those later ones had some weird deal - DRACS ? - but I am just not familiar with them. Weird that a cable driven one would quit working at the same time the tranny starting acting up, so I follow your logic there, right or wrong.
NVM me - just here for the ride. :dancingpoop:
Vbb199
Salisbury NC
Vince
90 and 91 both have a DRAC (for tire size and gear ratio programming), and a VSS.
This is just a cable, drive and driven gears in the tranny
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Gotcha.
Stupid questions - have you already pulled the upper & lower cables off the cruise module ( if there) and check if they turn by hand ? Focusing on the speedo issue.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
When I read the thread title my first thought was that it was about a wardrobe malfunction and all I could think was, please dear God, no pictures this time!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Without a speed signal, the converter won’t lock, and the cruise won’t work, etc.
If the speedo is cable driven, make sure the cable turns with the driveshaft spinning. If it’s an electric speedo, check the wiring, the connectors, look for corrosion or broken wires.
Vbb199
Salisbury NC
Vince
"this time"
What's that mean? Lmao
I'll have you know, I wear boxers :flipthebird:
Vbb199
Salisbury NC
Vince
Gotcha.
No sir, I haven't done anything yet, and it's raining here!
Doesn't the 89 have a cable driven speedo cable that drives that weird light sensor dealio? Its the sensor that feeds the pulse signal to the ECM, right?
12turnda
