Speedo Issue
Norwester
Battle Ground, WA
C-10
The odometer works on my '86 but the speedometer does not.
Should I just assume I need a new speedometer or is there a possible fix?
yevgenievich
Viktor
sad
very sad
less sad
Broken spedometer would be my assumption as well. If you want odometer to match then the replacement spedo would have to be taken apart to change the miles. Likely same as fixing the original.
Norwester
Battle Ground, WA
C-10
I think you confirmed my suspicions.......thank you for your response
aultinator
