Soldering equipment....one better than another?
Looking to start teaching myself how to solder. With that I need to buy some stuff. Is one brand better than the others when it comes to soldering devices?
Georgeb
Wisconsin
George
K10 Burb Z71
what do you plan to solder? small components onto boards or wires to wires and the such?
jetman
Minnie, AK
Don
If your soldering on a commercial volume basis, the high dollar equipment makes things much easier and is worth the money. For learning or doing periodic repairs simple HF equipment will fill the bill.
Georgeb
Wisconsin
George
K10 Burb Z71
Mostly just wires to wires. Nothing too major.
Thanks for the insight. Mine would definitely be periodic to go along with this weekend car hobby :) So HF is decent for the hobbyist and won't break after 3 uses?
74 Shortbed
Thank you :handshake:
You're welcome, buy em once and that's it mine are over 25yrs old and still like new and I use the **** out of them.
After looking at those pics my dad has one like that black gun style.
Any preference on what type of solder to use?
Georgeb
Wisconsin
George
K10 Burb Z71
Most of what you find in a store will be lead free but if you can find some with lead it will work better. In most cases rosin core will be the most convenient to use.
What about the rosin core makes it better? Create a better connection between the wires?
Georgeb
Wisconsin
George
K10 Burb Z71
you will need rosen either way to get it to stick. rosin is another name for flux. it acts like a cleaner. I don't like having to flux and then solder unless it is on really small stuff that requires very little solder.
Makes sense! Thank you :) I'm searching the interwebs now
74 Shortbed
I use rosin core, clean and quick no need for separate flux.
aaron06
