'Snowfighter' dana 60 swap
Reaperbond
Northern california
Devin
Hello all. I'm swapping a 1978-1979 "snowfighter" f350 dana 60 into my 1983 k20. Right now i have just 2 questions refarding this swap.
First one concerns the u-bolts: due to the way that chevy and ford mounted the axles being fundamentally different, im wondering how to mount the ubolt (using GM ubolts/mounts) on the driver side directly next to the pumpkin, seeing is there is a piece of webbing (or structure) coming off the pumpkin and terminating at the axle shaft housing, right where the u-bolt is supposed to mount. I am perfectly fine with taking a grinder to it and making a spot for the u-bolt to mount but I just want to see if this is what others have done or found an alternative method.
Second question involves the steering components: my pickup has a 6" lift so I'm wondering if I should get an after-market Pittman arm to replace on the dana 60 or try to find a steering arm to drop the drag link down from the gearbox.
Thanks in advance!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I dunno, I just have a passenger side D60. Out of curiosity, what are you using for a transfer case and rear axle?
CSFJ
It's been a while since I was fluent in Ford axles so I may be off base, but isn't the spring spacing different between the GM and Ford also?
MrMarty51
Eastern Montana
Martin
I know not one thing about the axle swap, just saying welcome to the GMSB forum. If it is a snow fighter differential/axle, bring it over, we are suppose to be getting some snow tomorrow so You can try it out. :happy160::happy175::happy175::happy175:
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
dvdswan
Port Orchard, WA
Dave
Welcome to the site. I would locate a passenger side drop dana 60. less headaches.
Reaperbond
Northern california
Devin
Thanks everyone for the warm welcome! I got a good laugh about trying it out in the snow haha!
Concerning the axle, the 1978-1979 f350 dana 60 has the same spring spacing (within 1/2") of the chevy spring perches. It took some looking but I finally found the darned thing after looking for 2 years. Unfortunately, the transfer case I'm installing is a driver's drop so I can't use a passenger dana 60.
Craig 85
Nashville, TN
454/TH-400/NP205
Are you asking about the webbing under the axle (photo 1)? GM style passenger drop D60's only have 3 U-bolts. The inner passenger side uses studs mounted in the pumpkin (photo 2, dually version axle).
With regards to the Pitman arm, I just used a Skyjacker CA50 arm, but I have a K30 and only went with a 3" lift. I had a K5 back in the early 90's with a 6" lift. I used a raised steering arm and one of those "S" type drag links (PITA). If I had to do it again, I would have used the dropped pitman arm and ORD's steering block #U9018 with a stock style drag link.
My drop arm (Skyjacker CA50)
ORD's D60 Steering arm block
Reaperbond
Northern california
Devin
Craig, thank you very much for the info. This is exactly what i was looking for. You were correct about the webbing under the axle in photo 1. Good to know about the 3 ubolts in gm dana 60's, I wasnt aware of that. I will look into the steering arm riser and the lowered pitman arm for the steering.
tweeter68
