Small block and starters
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
On my 70 with a small block GM, I believe engine, the starter bolts with three horizontal bolts to the bell housing. Ever other small block GM I've been aware of uses 2 vertical into the engine block. As well it is a running old bugger! Best I can recall I bought the old truck in 08 ish... either the engine was fresh or some one took it out and painted it orange...
Any one have any information on what I may have in the old 70?
Thanks
Shakey
idahovette
Weiser Idaho
Perry
K20-K10
Are there any bolt holes in the block where the starter would normally go? May have an old style bellhousing someone just threw on there to make it work?
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
not that I am aware of. Was a long time ago I changed the starter, and do not recall bolt holes nor a flat spot on the block....
custodian
Catawba
William
5.3 LS, 350
Some older bell housing had the stater bolted directly to the bell housing instead of the block.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Any idea year models on them? Same bolt pattern block to bell housing? I cant find a starter for a GM with this set up????
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
My memory may be wrong, but that sounds like the 230/250/292 I-6 bellhousing.
And as for block to bellhousing pattern, I believe the 235 (OLD school) was different, but the 230,250,292,283,302,305,307,327,350,400 and all the big blocks were the same pattern.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
This is a v 8 so...... know nothing at all about inline 6's??
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I have run a few sixes many decades ago, and I seem to recall they used the three bolt to the bellhousing starter.
Just for giggles, do a parts search for a 250 starter from the mid sixties, see what they show.
custodian
Catawba
William
5.3 LS, 350
The one I had was in a 67 C10, manual trans, 6 cylinder that I put a 283 in.
idahovette
Weiser Idaho
Perry
K20-K10
If you have a cast iron bellhousing it's not original to a square, I'm pretty sure . Think the cast ended in the middle to late 60's. If I'm wrong someone will chime in.My 56 Chevy 2 dr 210 had a cast bellhousing with mounts to the frame on each side and a 3 bolt starter. It was a 265 with no bolt holes in the block for a starter. Kevin is right about the engines he listed for the pattern on the bell to block.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I had a brainfart !!
I completely forgot about the 265 in my list.
Thanks for jogging the dust covered brain cell.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
That worked, parently they run from 60 to 72 in basically everything 402? and down.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Actually this shouldn't be in this forum. It is a 70 model C 30. so sorry. Though I did learn, so thanks! Thank you as well Kevin.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
You're very welcome, but don't tell anybody that I had a lucid moment.
As for being in the wrong forum, just wait until I go pick up a truck a friend has wanted to give me for 30 years, a 1942 GMC 6x6 10 wheel drive 2 and a half tom flatbed .....
Washington
Say what??
That’s seriously cool!
Short or long wheelbase?
ruggedly
