Side window defrost add?
It rained all night and most of this morning here. I just went through the cab and can't find anywhere wet except for the flat side of the floor pan passenger side. That is almost always damp though because that soundproofing mat holds the moisture.
Sent from my SM-G950U using Tapatalk
It could be running under the carpet, then only getting wet where it pools. You can poke around under the dash, looking for traces of water leaking down the firewall and kick panel. Or you can pull up the carpet, close the doors and hose it down real well. It also helps to have the dash pad and glovebox removed.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
This.
I’ve rehabbed dozens of homes. The ones cheap enough to turn a profit usually have leaks. Water will settle where it will, often farther than you’d think from the source—thanks in part to surface tension and gravity.
Interesting the turns a thread can take...lol
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I'm gonna run a strip of paper across the bottom of the firewall at the carpets edge and see where water marks show up
NICK DANGER
Mid Michigan
Nick
C10s, K5 , truck Jimmy hybrid "Trimmy" . CUCV - M1009 M1008
350 tbi/ 6.2 diesels
Just crack open the side vent window ...
Pull up the carpet, use a blow dryer to dry the floor then spray the outside with a hose. You'll see where it's coming from.
78C10BigTen
pennsylvannia
C10 BIG TEN
I had to drive in a thunderstorm with no defrost and I was able to keep it defrosted pretty well with the vent window opened a bit.
Another benefit to my favorite window in my square. They never shoulda got rid of wing windows or manual floor vents. Old trucks are so much cooler.
78C10BigTen
pennsylvannia
C10 BIG TEN
That's a very good possibility. Ive been trying to chase down why my passenger floor is always wet.
Heater core?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ya I was thinking of grabbing a newer dash to swap in. But if I could easily just add side vents and paint mine I'd be good.
98 up VW Passats have little round vents with angled louvres for side defrost might wanna pop one out at a yard and take a look.they are about the size of a silver dollar
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I also think my manual lower side vents maybe leaking. I can feel cold air coming from them when closed.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
@usar17
86Apache
Banned
WV
Marvin
C10's ,K20
250 six, 350's
Perhaps more rest-stops for your wife would help?? ;)
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Bumps. Defrost worked nice the other day in the snow. Rain tho has always been the worse for sides fogging.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
07 Silverado this would meld well with these dashes
Big Chip
Michigan
Kevin
C35
Did you find the source of the water yet?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
No I have been dealing with a ton of other stuff lately.
guillermoariast
