shim ?
kdo58
Puyallup wa.
k5
i have a 75 k5 with a 4" lift, i have cv drive shaft in the rear, any idea what degree of shim i should buy, so my pinion is in line with my driveline?
MadOgre
NA
NA
NA
NA
NA
The local 4x4 shop doesn't know?
CSFJ
If you're running the cv style rear shaft, it would seem to me that the degree of incline needed to point the pinion at the proper angle, would be outside of what a shim would provide. typically you would need to remove the spring perches and rotate the axle where it needs to be, and re-weld the perches. At least that's how it's handled on a jeep.
tweeter68
