Shaking a Metal basket full of marbles!
racinjasonm3
Pittsburgh
Jason
Chevy K20 Suburban
That is what my tranny sounded like just before it stopped working. No park, drive gears, or reverse.
Does this mean...time to buy a new one, or could I get away with a rebuild?
Looking for any solid guidance. Thanks!
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
What year and model of truck and transmission, what kind of driving do you do and what are the vehicle demands, and are you saying that the transmission has already been deemed a catastrophic failure?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
By your description it sounds like it blew apart internally.
74 Shortbed
Something is definitely broke inside, time to pull it apart I wouldn't even start it up again it'll only make it worse.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Probably exploded the drum if there is no park that's just a spring loaded pawl that latches into teeth on the drum.
racinjasonm3
Pittsburgh
Jason
Chevy K20 Suburban
Thanks for the tip. Any idea where I should get parts?
racinjasonm3
Pittsburgh
Jason
Chevy K20 Suburban
It's an 83 Suburban K20. Street driving only. It is a 400. No one has looked at the transmission yet. The truck will not engage any gear including park.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
More then likely th case is damaged inside. I have a 2 wheel drive th400 if you wanna take a drive east. You'd have to have the output shaft swapped over. It's a HD with the deep pan out of an R30. But at any rate replacing your current one will probably be the most cost effective route. Any thought @74 Shortbed ?
Did the shift linkage perhaps fall off? What does the fluid on the stick look like?
Bhardiman1
