Selector valve 1983 Sierra classic 1500
JustinWeber32
lago vista
justin
The passenger tank doesn’t work on my pickup. I’m going to replace the selector valve. Some of the hoses have been replaced and I wanted to make sure they were done properly before I took it apart. There is on hose that feeds right back into another port. I wanted to make sure that is correct, or if that is supposed to go somewhere else. If not, does anyone have a picture of there’s I can go off of? I’ll add a picture of mine.
Thank you
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
Try these:
  • Pollak Multi Tank Swtching Valve Instructions_2.pdf
JustinWeber32
lago vista
justin
Thank you. Looking at it, I believe they bypassed the selector valve and ran the fuel line straight to the drivers side tank line. That diagram will help though.
chevytech87
Tomball, TX
Brandon
GMC R1500
Definitely what it looks like to me. I just replaced my valve on my 87 a few months ago after it got stuck. Make sure to take a good look at your connector at the valve while you’re there. If it looks gross to the point of no return replace it. Intermittent connections back there get really annoying really fast.
JustinWeber32
lago vista
justin
Okay, thanks for letting me know. I’ll probably just replace it to be safe.
78C10BigTen
pennsylvannia
C10 BIG TEN
All this makes me glad that mines has a 3 port single wire!! Btw MANY thanks to Mr. Aydo for this! @AyWoSch Motors
SirRobyn0
Rob
Not to hi-jack the OPs thread ( and you may already know this) but for anyone that doesn't GM went away from the single wire valves and because they are less reliable. Two issues, one is that it is powered and it switches to one tank, cut the power and a spring inside the unit switches it to the other tank, issues with that internal spring can prevent the tank from switching, but because the gauge is controlled by the switch on the dash the gauge changes and the driver is unaware the tank did not. So the 5 or 7 wire, there were both the polarity is reversed when the switch is flipped so the solenoid inside the valve is powered in both directions making for a more reliable valve, but also the gauge change became part of the valve so if the valve fails to change the tank, the gauge won't change.
Dan_R
