Running good then misfiring?
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
So I was at Trollhaugen riding the trails this weekend. The truck did great other than the fact that it would run fine for about a minute then start bogging, droning and misfiring real bad on 4 to 6 cylinders (I think) It would loose a lot of power, idle down to about 600 rpm and barely run. When I would hit the gas at all it would barely bring up the RPM's and it would keep running bad and dying if I tried to put the truck in gear and move it unless it was on flat ground with no resistance. I replaced the distributor cap, rotor, ignition module, Saturday night and plug wires a few weeks ago. I am really at a loss on what it could be at this point and it's starting to piss me off.:shrug:
87scotty
Central il
Andrew
V20
5.7 for now
Carb?
87scotty
Central il
Andrew
V20
5.7 for now
What do plugs and air cleaner look like
87ChevyR10
Kansas
NA
NA
NA
This is a spark plug:
This is an air cleaner:
I hope that clears up any confusion. XP
87scotty
Central il
Andrew
V20
5.7 for now
Bahahaha we got a comedian
87scotty
Central il
Andrew
V20
5.7 for now
Also last fuel filter change?
87ChevyR10
Kansas
NA
NA
NA
I would take a look at the floats. They could be binding in the carb once your truck hits an incline and not allowing enough fuel into the carb itself. Just a thought.
87scotty
Central il
Andrew
V20
5.7 for now
I get the new plugs but are they soaked in fuel or dry I agree with r10 carb issue or fuel delivery to carb
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
Carb might make sense. Fuel delivery would make sense because when I was trying to "hot rod" it through mud holes it would surge along with the other issues. I'll check my carb and see what I find.
redneckgames
