Rough country 2 in lift leafs
bluecamden85
Ohio
Sierra
I bought a rough country 2" lift , leafs front and back. Shocks and hardware will be here tomorrow . I got the leaf springs today but I noticed that the rear don't have a wedge or a flat leaf ( wedge thin end faces forward). Am I missing something?
bluecamden85
Ohio
Sierra
bluecamden85
Ohio
Sierra
bluecamden85
Ohio
Sierra
rpcraft
Robert
LS 6.0 364 CID
Call them and ask or maybe check over the instructions if there are any?
bluecamden85
Ohio
Sierra
Lol I just seen this Im learning how to work this forum. Heck I don't even have a Facebook or any other social media . I started a different thread.
rpcraft
Robert
LS 6.0 364 CID
Now that I think about it some most kits have blocks that have the angle built into them but since you got leaves for the rear often times they have a small angle shim that is bolted to the leaf stack so you might check and see if you have one on the bottom of the rears. sounds like you did thought but I'm just tossing out the idea you are overlooking it by thinking it may be loose. Hope you find it.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
I bought the same kit a good 7-8 years ago, didn't need any shims or blocks or spacers. The springs are designed to compensate. Blocks are not what you want, lift springs are much better. Don't worry, you're fine.
Some people might complain and say that RC lift springs are stiff and have a harsh ride, but it doesn't bother me (or a lot of people). Whether people dispute that fact or not, I don't think there's anyone who will say RC is a bad quality kit. I've never heard of anyone having fitment or durability issues, just the occasional fart that doesn't realize lifting a 30-40+ year old leaf sprung truck might make it ride a little less cushy than a brand new Escalade...
ali_c20
Austria
Alexander
C20, K5
The angle should be fine as the springs are made for a model specific. Installed 3 lift kits and never had to correct the angle.
Depending on the application and truck's usage, lift springs are not always better than quality cast steel blocks.
Rough Country tends to make decent stuff. It's just that some people aren't OK with a ride quality that is significantly rougher than the factory springs. But if you are fine with a bouncy truck that tends to jounce around over pot holes and expansion joints in the road surface, you'll be fine.
The fact that there's no overload leaf is probably an indicator of the spring rate. With only 2" lift, degree shims probably aren't needed.
mshawn
Malvern,Ar
Micah
c10,jimmy,k10
I just purchased the same kit about a month ago I have it sitting in my shop and I can look at it if you need or snap pictures. If that helps. I can’t open your pictures for some reason. Mine is for my GMC Jimmy fullsize 4x4 6.2L diesel. 1984 52 inch spring rear.
bluecamden85
Ohio
Sierra
Trying to get it on now. I started a new thread . Leaf spring shackle help. Ran into shackle bolts snapping. Grinding down rivets.
scawdrey
