Restoration help
Frankie
Three Rivers, Michigan
Frank
R3500
Bed is in excellent shape too. Getting ready to remove it via a tree. Lol
Frankie
Frank
R3500
Finally found gas tank supports, took a bit. Would like prebent ss brake lines. Found pieces but not main run.
May have issues with locating upper and lower control arms.
Oh a steering column would be nice, tilt is broke, planned on rebuilding. Front suspension is 87 for sure as is column.
Finally located rear leafs and overload spring. Still need the u-bolts to mount it, 3 where broke. Yep still drove fine. Lol
Frankie
Frank
R3500
My son is doing most, if not all the work. 18 and is having fun. Wants it as a show, sunny driver truck. Will never haul again.
Big Chip
Michigan
Kevin
C35
I would try inline tube for the brake line. I bought Moog control arms, yours are the same as mine and they are the same right up to the end of the run too. The column should be easy enough to find and there's a column interchange list on the forum somewhere. There's a spring shop near me that had those rear springs in stock, those are the same all through the dually run too.
Frankie
Frank
R3500
Would like close to stock springs. SD SPRINGS has them as well as the over load. Just not sure how stock they are as they have different load ranges available. Both my leafs have multiple broken leafs in the pack as well as deformed over load. Any names of places would be great.
Big Chip
Michigan
Kevin
C35
McVeigh Truck Spring in Mio or you could try Michigan Truck Spring in Saginaw. I know McVeigh's makes their own ubolts so you can get whatever you need. You should be able to tell what the stock springs are with the SPID in the glovebox.
darrel
