Replacing ESC (electronic spark control) for standard HEI distributer
KRBishop
Boston, MA
Kyle
C10 Silverado
Hello - Narrowed down an issue to what we think is a faulty ESC (electronic spark control). We are planning to swap the computer controlled distributor for for standard vacuum HEI distributer.
If we do this, will if effect anything else? Carburetor? Tranny? I did a search on here and other forums and have seen people say that they have done this change, but they never mention if anything else needs to be change when you do this.
Truck is 84' C10 w/ 305 / 700R4 Tranny
Thank you in advance.
Waylon
Waylon
K1500
As far as I know, nothing else has to change. Just check your timing afterwards for initial timing and advanced and adjust if needed.
Been done lots of times and it all depends on who you talk too as to whether they are happy. I wasn't,as for changing it out and it bolts right in place. Timing is the problem when you advance it enough for decent power and mpg, it pings bad when you pull out enough timing to get rid of ping you lose your power and mpg. At least swap in your weights, springs, vacuum advance,and distributor cam.
Wrenchersllc
