Replacement Door Panels
Splandman
Crescent, OK
Scott
Is there a difference between the replacement door panels offered by LMC versus those offered by Classic Industries or Brothers? Just curious if they all get them from the same manufacturer or if they are different and one is higher quality than the others.
WillSquared
Arkansas
Will
Based on what I've seen there are essentially two aftermarket replacement door panels available. The LMC style ones are plastic (basically), utilize stock or very similar to stock trim and have no fabric inserts. The Classic Industries style ones are also plastic but they don't use the factory trim to the same degree and instead have a fabric insert that takes the place of the upper silver piece. This is all on 81-87 panels. I'm not sure about the earlier ones.
Splandman
Crescent, OK
Scott
Both of the trucks I will need door panels for are 70's. A 75 and a 78. The 78 I probably won't be overly picky on but I would like the 74 to be as close to stock looking as possible.
WillSquared
Arkansas
Will
Ah, well youre welcome for the no help I just was :cheers:
Splandman
Crescent, OK
Scott
I appreciate the response and am pretty sure I will end up buying another truck built after 81 at some point so all info is good.
1983GMCGuy
Oklahoma
1500 Sierra Classic
Thanks for the info! I'm inbthe process of locating new panels, so thanks for the info
Sent from my iPad using Tapatalk
Misty Blue
