Replace thermostat without draining fluid?
thecantaloupeman
US
Dawson
C20 Silverado Camper Special
So I just finished my coolant flush and silly old me forgot to put the thermostat back in before filling it to the to with new coolant. Can I put a glove around the upper radiator hose to plug the fluid so I can replace the t-stat without draining the fluid below the housing? Thanks.
DBarre
Rockport, Texas
Dustin
250c.i./4.1L
Just get a clean bucket and reuse the coolant you drain out. It probably won't even be a whole gallon!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I'm no genius, and I may be doing it wrong, no sarcasm intended, but I've changed a thermostat with it full of coolant....
Sent from my SM-G965U using Tapatalk
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
You'll lose a little coolant, but the whole thing isn't gonna empty out like if you took the lower radiator hose off or something
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
Just undo the bolts to the housing with the hose still on and have it point vertically while you change it, should be a small mess but nothing more than a quart or two at most.
78C10BigTen
pennsylvannia
C10 BIG TEN
Buy a pair of hose pinch pliers and squeeze the hose in front of the housing before removal
80BrownK10
Greenwood, SC
Nate
Or undo it and fold it back. But if you have a set of pinch pliars like that you can do that or use two pieces of wood and regular vice grips to pinch it off.
Or like said just drain a half gallon or so into a clean bucket and pour it back in.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Drain a little coolant, then swap the T-stat. When your ready to pour the coolant back in run it thru a paint or coffee filter to catch any crud that may have fallen into the catch pan.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Cheese cloth works well also for filtering coolant. Use anti-sieze on your housing bolt threads.
Clayton
Sent from my LM-V350 using Tapatalk
SquareRoot
Liquid flows from high to low. Any fluid above the level of the t-stat housing will push out the fluid below it. If you hold the upper hose vertical with fluid in it, it will push up thru the block and out the manifold. Just drain enough fluid out the petcock to lower the level in the system to the stat housing and pour it back in when you're done.
thecantaloupeman
US
Dawson
Okay I replaced that thermostat and It leaks a bit. I misaligned the gasket, but I wanted to know is there a right and wrong direction to put the thermostat? One side was flat with darker blue stripes, and the other had a bevel and was just plain blue.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Are you talking about the gasket?.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
The gasket shouldn't matter, both sides are the same.
thecantaloupeman
US
Dawson
Yes sorry I was talking about the gasket.
RecklessWOT
New Hampshire
Kevin
The gasket doesn't matter which side is up because it's a basic shape, it's the same either way.
The important part is making sure the bolts are tight enough (but not too tight where you blow the gasket out), and you also want to make sure the surface where the gasket seals is clean before you put the new gasket on. If there's remnants of the old gasket left behind or just crusty crud that gets on/under the gasket it will not seal well. A gasket needs to be evenly pressed between two flat metal surfaces. If you have to go in there with a razor blade or paint scraper to get the old gasket off, that's what you gotta do (especially if the guy before you put silicone or something on there). You need to completely remove the old gasket.
builder100
