Rear disc brakes on the cheap
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Just wanted to bring this back alive.
Anyone ever do a step by step with the Impala setup?
When I did mine it was very none evasive and used all GM stuff, just from different years.
350runner
tx
Ceasar
Has anyone figured how to make the parking brake work?
Sent from my LG-LS993 using Tapatalk
rpcraft
Robert
LS 6.0 364 CID
It's not that hard to find the six lug pattern with slip on rotors the problem has been trying to find rotors that would work with the five lug setup. And about the parking brake, if you want a Parking brake setup then go to speedway motors and they offer a rear disc parking brake setup that is still not horribly priced. But as for me I don't give a **** about a parking brake.
The problem has been finding a setup that incudes the ebrake. There are a number of solutions that could be bolted on but many states will check for E-brakes and that is where the issue comes to bear.
When I get home I will elaborate
You used the K10 front calipers and mounts, drilled to fit the rear housing flange, and used '88-'98 4x4 front rotors. Right?
Anyone using that setup should be able to use the Eldorado rear calipers. The parking brake will be iffy at best, but no worse than a brand new '78 Eldorado, lol.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I used K10 brackets redrilled and machined to fit the flange and welleded a stop on. I used 96ish blazer rotors with the centers machines to fit the axle and machined .100 off each side and K10 calipers.That was for 6 lug. He is 5 luv so he can use the 5x5 Astro rear set up @78C10BigTen
That would be front rotors for an AWD Astro, right? And an older model, at some point after '00 they went to 6-lug.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Most of the the time they are not setup correctly. It's a bit of a process and must be done to the book from what I understand. I don't have personal experience... but I do have a set of these in my project parts collection.
And if you have 'em use 'em... this will keep them in order but you would still need the extra maintenance of keeping them clean from off roading. Fortunately they are easy to get at.
I still want line locks and a brake at my TC... These don't count in BC I would still need the rear park brakes.
Charkmapman
