Rear cab trim- installation questions when trim is missing
Evans Ward
GA
Evans
Sierra Classic 1500
The PO of my 87 Sierra Classic removed all of the rear cab stainless trim. I want to put it back on as I like that feature/ look. I found all of the the trim at the salvage yard but the long straight piece have a few too many dings for me to use. The GMC corner pieces are nice and only needed a red touch up. I'm looking at the repop piece LMC has- anyone here seen or used it? I will need to drill the hole for the corner molding stud/speed nut and will make a template. Does anyone have a good reference of how/ where to locate all of the trim? I could also use a pic of rear clip spacing for the long piece. How many clips needed? I'll use small stainless screws. Has anyone taken this project on before?
chengny
Rear cab trim clips. Spacing is not critical - 5 required:
At Classic Parts - $1.95 per:
http://www.classicparts.com/1981-87-Rear-Cab-Trim-Clip-Center/productinfo/62-927/#.VRNDuvw4gcM
Special screws for mounting rear molding clips:
Special retainer clip screw for center rear cab trim. Requires 8 per truck for 1973-80 and 5 per truck for 1981-87.
Available for $1.79 each at Classic Parts:
http://www.classicparts.com/1973-87-Rear-Cab-Trim-Clip-Screw-Center/productinfo/62-929/#.VRNHa_w4gcM
Some info on placement and parts - corner & rear trim pieces:
Shows placement of corner trim - this truck is a 1987 Sierra Classic that I recently stripped for parts:
Parts dwg and lists:
BTW - those trim pieces are brushed aluminum, not stainless steel.
Evans Ward
GA
Evans
Sierra Classic 1500
Thank you as that is very helpful info you supplied!
ceyman72
