Re-painted the Stock Intake and Oil pan
garzas23
Brazoria County TX
AJ
Bein an old engine there has been grime everywhere! first i degreased it with purple power degreaser, cleaned the rust and original coating with a wire wheel. Then i use Duplicolor prep spray to get any grease or rust left. Finally I used VHT aluminum engine enamel a few coats each then a good clear coat for a little shine, also VHT. So far I'm very please with the outcome. I will have more pics soon i have the block and heads painted black
350runner
tx
Ceasar
Very nice job bud!
Hoodbj
Billy
That should look great with the black contrast. Good job!
chengny
carlgm
Fl
Karl
'85
Looks good. How many coats of VHT enamel did you put?
chengny
Except for the manifolds, I make my hillbilly chrome with just a couple of light coats of Duplicolor's silver caliper paint.
Sandblast/paint strip the part. Wipe down with generous amounts of gasoline. Wash in warm soapy water. Rinse real good. Let dry. Wipe clean again with acetone.
Heat the caliper paint in a hot water bath to aid in atomization and lay-down. Two or three light/medium coats - let flash dry between coats. When the finish looks good, let the paint dry for a few hours.
Bake in the oven for a couple of hours at 250 F. Let cool with the oven door closed for a couple of hours. Bake again for 2-3 hours at 350 F. Let cool - again with the oven closed.
That's all.
MadOgre
NA
NA
NA
NA
NA
That's all.
Do you tell the ol lady that your baking muffins?
Dadof2
Central Texas
R1500 Chevy Sub, C20
350 in both trucks
Well done!
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Good job!. Its going to look great once put all back together. I need to do this to mine also. :cheers:
chevymanmike
edinboro pa
michael
scottsdale c10
looks great lets see some more pictures
Snips71
