Quality Diff cover recommendations needed
Dezzracer
Las Vegas
K10 Scottsdale
Hello all. New member as of today. Just finished frame off 1976 K10 resto. Looking for recommendation on diff covers for Dana44 10 bolt front and G.M. corp. 12 bolt rear. The cheap chrome ones leak no matter what we do to seal them. I would prefer GM NOS but cant find any. I want good high quality aluminum (or steel) in black, unfinished metal maybe gunmetal. Thanks in advance.
newguy11
New England
Private
C/k 10
Is it not worth refinishing a factory used cover from the boneyard? You know it’ll fit well.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Easton went with a summit racing one
ali_c20
Austria
Alexander
C20, K5
I refurbished the original diff cover of my 14bolt ff axle and added a drain plug with magnetic bolt.
On my k5 I have the summit racing aluminum ones. Not the prettiest covers but they don't leak, the material is pretty thick and they are black.
Front: https://www.summitracing.com/parts/sum-730507b
Rear: https://www.summitracing.com/parts/sum-730503b
Some interesting videos about diff covers and what's going on in the rear end:
Dezzracer
Las Vegas
K10 Scottsdale
Thanks guys. I found two black aluminum I like and should work. Apparently they chrome the inside mating surface is not always chromed evenly thus causing leakage. Or some of chrome chips off also causing leakage. From what I have learned the chrome ones often leak.
aaron06
