Q-Jet choke plate stuck open
MadOgre
NA
NA
NA
NA
NA
Yes the linkage is messed up.
This is wrong!
The linkage is supposed to be shaped like that!
MadOgre
NA
NA
NA
NA
NA
Did you happen to see post 42? that is what it looks now.
I straightened the rod on the choke plate
Bend it back then. Its supposed to be bent like that!
MadOgre
NA
NA
NA
NA
NA
Yes, flooring it is correct.
Try bending the choke rod that goes to the vacuum pull off, so that it is in about the middle of the slot, see if that makes a difference. I am just guessing at this but, I think with that choke rod bent right tight against the pull off, might be interfering with the operation of the choke.
Someone correct Me if I am wrong.
Yes you are wrong
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Admittedly, I am not good with carbs...
I fully rebuilt the throttle body in his crew cab in 45 minutes and it took that long because I was teaching him how to do it.
MadOgre
NA
NA
NA
NA
NA
haha well by the time this poor guy is finished bending all his linkages out of spec hes gonna need a new carb lol
Georgeb
Wisconsin
George
K10 Burb Z71
This is wrong!
I know its supposed to be bent some but the bend in it seemes excessive. I wasn't implying it should be straight. I'm not implying to bend the **** out of everything I am sying someone already did and it's all jacked up.
Georgeb
Wisconsin
George
K10 Burb Z71
The rod to the choke plate is supposed to be bent like madogre said. I guess I didn't remember how much tho. I still thing the linkage fron the choke spring is wrong tho. Sorry for any misinformation on my part.
raylanr
Campeche, MEX
Franc
I think everyone is trying to help. The linkage for the plate was bend but I think it twist.
I appreciate you all taking time to help me. We will get it figure out
raylanr
Campeche, MEX
Franc
How is that for a blow out picture.
My wife got me this book a while back just never open it.
Is called motor truck repair
raylanr
Campeche, MEX
Franc
Quick update. I bend the rod back in to what I think will work... But I find out the cable to the distributor cap was yanked. Which I will be replacing soon
Sent from my SAMSUNG-SM-N900A using Tapatalk
ebob14
