Power Steering Return Fitting
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Anyone have a good part number or description for this part? It is the nipple that threads into the power steering gearbox for the return line to attach to. I'm pretty sure my box is metric (correct me if I'm wrong).
Nothing really goes wrong with them, but you are missing the o-ring that goes on the flare.
There's an actual name for that specific flare fitting, but it escapes me at the moment :doh2:
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
The second picture is the remnants of the o-ring. I didn't think the metric fittings have a flare. I thought they were flat with the o-ring.
MisterB
Northwest
AJ
GMC K2500 4X4
Your rag joint looks shot. Bet your steering is loose and wanders?
Sent from my SM-N975U1 using Tapatalk
That mild flare is there mostly to keep the o-ring from falling off during the installation.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
No idea. Bought it without an engine and just finishing up the swap.
Looks OK to me?
MisterB
Northwest
AJ
GMC K2500 4X4
Looks OK to me?
Well, maybe so. It just looks really oil saturated and old and the rest is cruddy and rusty. I'd be surprised if it isn't making his steering less than optimum
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Oh, I definitely poured about a quart of brake fluid all over everything. I did learn what a rag joint is so that's helpful.
HOTFOOT
northwest ct
michael
gmc k3500 srw
it is a 16mm o-ring . you only need a o-ring.
o
Karguy
