power steering questin
k5krawler
Auburn
nick
k5 blazer
ok so il leaking baddd not on the fitting but on the top of the fitting like the flange isnt sealing
anything suggestible :rape:
8T6K5
AZ
L98 350 TPI
Move up to cross over/high steer set up....
k5krawler
Auburn
nick
k5 blazer
hahaha hate to tell ya but high steer has nothing to do with a powersteering leak
"not on the fitting but on the top of the fitting like the flange isnt sealing"
What do you mean by flange?
The power steering pumps I'm familiar with have 2 hoses connected to them. One is the return from the steering gear (low pressure) and the end is just made up to the nipple with a hose clamp. Forget about that right?
The other one has a shaped steel piece of tubing for the last few inches.
That's probably the one you mean. That is the pump discharge - it's high pressure and makes up to the pump in two different types of terminations depending on year of manufacture.
Older pumps accepted a double flare (inverted flare) that was a metal-to-metal seal. I think around 1978 -80 GM switched to an o-ring compression type fitting.
The two types look very similar from outside. But they don't mix and match.
If, for example, you have the type of pressure hose that requires an o-ring srewed into an older pump with a female flare connection it'll leak (even if the o-ring is in place).
And, if you are trying to couple a new style pump to old style fitting, it will leak as well.
8T6K5
AZ
L98 350 TPI
No ****. But with your large tires your system might not always be working so hard.
Sent from my iPad using Tapatalk
Snips71
