Power steering pump bracket for heads without accessory holes.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Like John says above, Alan Groves! Keith was great! And priced so even a 16 year old couldn’t complain.
Randy and Easton
Randy and Easton
if he goes that route like you, i would get a hydroboost reservoir and cap off the extra return and then have the cap placed higher and closer to the fender a bit and it would look ok I think
ChuckN
Bellinham, WA
Chad
So that’s a good question-looks like my pump is leaking a bit. What is hydroboost? They asked me what kind I have and honestly- just looks like a teardrop style with two lines, one pressure and one return.
Edit: I looked it up. It’s for power brakes for engines without vacuum.
ChuckN
Bellinham, WA
Chad
Randy and Easton
That looks nice! I like the look of the raw steering pump too.
mshawn
Malvern,Ar
Micah
c10,jimmy,k10
the old corvettes and Camaros use the double hump heads. The bolted to the outside edge of the block. Any corvette Camaros restoration may have them. I think I’ve got the brackets in my shop somewhere. Anyway it’s 2 brackets. Very easy to install. I cant look this weekend. I’m flying to camp lejuene. Be back on Monday but got to be back at work so next Friday (Dec. 9)that I will be back in the shop and I will look for them.
mshawn
Malvern,Ar
Micah
c10,jimmy,k10
66,67,68 maybe more I don’t remember. Any other Chevrolet cars running the higher hp 327 will have the same double hump heads with the same power steering set up. Most of your late 60s model designated “SS”
They ran double humps into the early 70s on the lt1 Motors. The double hump part is irrelevant what is relevant is pre 69,for cars pre 73 for trucks The short water pump cars didn't have bolt holes no matter what heads were on it. So they had different brackets.
Yes, the only reason I said so is the hydroboost reservoir is slightly larger capacity, would sit the "cap" slightly higher and slightly closer to the fender(relative to the one there now) and the reservoir has an extra return port. The extra fluid never hurts and the other features are really just QOL not essential, but worth it if you had to ever replace a seal or something.
Mark Jones
Horse Shoe Bay Tx/Thousand Oaks Ca
Mark
@Mark Jones Hey Mark, can you help Chad? What year and model is your P/S pump bracket from? Thanks.
!972 Nova power steering brackets, and alternator brackets, 1969 Z/28 pulleys. Works flawless, and I run it hard.
@Mark Jones what is the lower alternator bolt threaded into?
Mark Jones
Mark
The bolt threads into a nut behind the alternator, I use 2 brackets tig welded together for extra strength. You can actually see this in the first picture if you look hard. NO------------problem.
I thought it looked thicker than normal (phrasing oh my) lol, knew I was not insane.
Sparky32668
