Poor mpg
Wumbo
Illinois
Rob
before / after , what difference does it make anyways!??
serious though.
If your ignition REALLY IS set at 10° before top dead center , that's your problem.
Reset timing to 10° AFTER top dead center, take two aspirin and call me in the morning..
Don't bother posting without a pix.
Hope this helps!
o_O
Les Maples
Les
K1500
I'm hooking the timing light up here in a few and reset timing and see what that does.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
It’s definitely btdc. The flame front takes a certain amount of time to travel and you want it to explode at optimal cylinder pressure shortly after tdc. The faster your engine is spinning, the longer this can take, hence why advance will send it out to greater than 30btdc
if you aren’t pinging at wot with 8 degrees base, you’re in the neighborhood. Just make sure you’re checking it with vac advance disconnected. Then rev it out to ~3k and check to see that your mech advance is working. You can then reconnect your vac advance to full manifold vacuum and watch that it advances your timing at idle.
Les Maples
Les
K1500
Ok 10 after tdc starts easier for sure. I will see in the am when I go to work. Thanks for the help. I'll update you tomorrow
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Check for vacuum leaks. Could be tiny splits in any of the black hoses or caps under the hood. If your dizzy vac advance is starved for vacuum, it will affect cruise performance significantly. If it’s not vac advancing, it’s igniting too late. By then the piston is already too far down and you’re wasting gas. It’s like trying to push a kid on a swing but she’s just about traveled beyond your reach. You might barely connect at the end, but it was a wasted motion.
SirRobyn0
Rob
For your reference I have an 84 C20 350 700R4 I get 12 on my drive to and from work which starts out as county roads and ends in city traffic. On the highway I get a pretty consistent 16. 5 is terrible. BTW ignition timing should be BEFORE top dead center not after, 10 BTDC would be a little high for some 350's. I would be looking at the carb. The only time I have ever run into such a severe mileage loss that didn't have an obvious cause someone had put HUGE jets in the carb. Oddly enough that rig ran good and didn't foul plugs. Another thing might be if the timing chain is full of slop, or somehow running off a tooth, but you'd have a pretty severe power loss to go with that.
80BrownK10
Greenwood, SC
Nate
Hello, I just got this about 3 months ago and put a 350 in has a 700R4 with 3.08 gears. It was a total mess and now it's a daily driver. Love this truck.
Something bid bad wrong!! You sure you don't have a fuel leak? Are you timed right, carb adjusted, tuned up, brake not on, engine has any compression left?
I have a 350/350/205 k10 with 3.08 gears and I get about 10 mpg. I can get close to 12 if I want and drive slow. I get 8mpg pulling a 5-10,000 pound trailer. Oh and I am running on 33's.
AZ-520
c-10 2wd
5.9l
What's the general health of the engine, compression, timing chain slop etc. I like to run AFR gauges on carbs jet them just right. Sounds like you are getting there. Keep eliminating possibilities.
Lefthand6
Little River
AJ
I recently put a new carburetor on my c10 with a 350. One side of the carb was all the way lean (with screw ceased). The other side was all the way rich to make up for the lean side. The choke linkage was also broken. I was getting maybe 3 mpg. Now I am getting closer to 10 mpg. This is also moving my timing back from 16° tdc to 8° tdc.
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
My '78 K10 (350/TH350) runs about 8 mpg, which is pretty normal for these 4x4s, I would say.
Raybo135
Arvada, Colorado
Raymond
K10 Silverado
As I have always said about driving these trucks, "It is not miles per gallon that you should be worried about, it is SMILES per gallon. I was getting about 6.85 until my friend notice I had a short in my EFI and was firing the EFI all the time. The Electric Fuel sump was constantly clicking on and off. I am getting much better now. I have gone about 40 miles on the last fill-up and it hasn't moved off the Full mark. Fingers crossed! ! !
tubehead
australia
richard
c10 silverado
350HO 700r4 9 inch ford
diff 3.5 gears.Rebuilt quadrajet getting 16.8mpg driving like a granny around town.6mpg driven hard.
PapaBear8486
