Parts(misc, trim, wire, etc...)
yevgenievich
Viktor
sad
very sad
less sad
Updated list.
AC/heater control panel - $10+shipping
vacuum selector valve with the hoses. $5+shipping
89-91 suburban passenger side (right) turn signal/running light housing. $8+shipping
plastic cover from a footwell fresh air supply. $1+shipping
tbi fuel lines. $5+shipping
gear shifter part that works on the transmission. $5+shipping
89-91 air intake mount box. $5 + shipping
also have factory air cleaner enclosure( tube is gone) - $10 + shipping
front blue seatbelts, dirty but usable. $20+shipping
Complete front and back blue functioning seat belts in good shape - $250
3rd row blue seatbelts. a bit dirty, plastic cover broke the snap part. $20+shipping
ls ecm mount. $10+shipping
spicer one end of the driveshaft. Set for 700r4 ujoint size
ac vent driver side. $5+shipping
ashtray with housing. missing springs. $5 +shipping
dome light wiring. $10+shipping
suburban barn door strap. $5+shipping
blue suburban trim. $5+shipping
license plate light - $3+shipping
Condenser and evap cores in good shape. $20 each+shipping
Cab corner - $15+shipping
Windiw guides - $15+shipping
700r4 torque converter cover
$2+shipping
transmission cooler - $20 + shipping
deep 700r4 pan - $10 + shipping
not deep 700r4 pan - $10 + shipping
stock 17 bolt 4l80e pan - $20 + shipping
@yevgenievech....do you happen to have parts for the rear AC? Pic below and boxed in red
yevgenievich
Viktor
sad
very sad
less sad
I do have them.
How much to 64083 and when can you get them sent to me? :)
yevgenievich
Viktor
sad
very sad
less sad
Unfortunately it would be thursday or friday before i can pull it. Shipping about $18 . about $20 for the part it self
Ok....I'll send you a PM Thursday if I haven't gotten one by then and we can talk about getting you payment :waytogo:
@yevgenievich I'm sending you a PM now. Thank you, sir!
yevgenievich
Viktor
sad
very sad
less sad
Have a set of new door seals - $25 ( one of them was installed for couple of months, so your door will close better than the one that is never installed)
Also have complete tbi fuel sender/pump assembly. It was a new replacement unit in the suburban that i cut up last year. - $40
Have blower fan motor with the two cages for rear ac - $20
Front clip from 84 jimmy, has rust under the battery tra and some on the hood - $250
Front doors from 84 jimmy - $100
Rear crew cab or suburban doors - $100
Driver side barn door - $30
Grey headliner suburban - $40
Tan dash pad from 84 jimmy, some cracks - $40
3.73 open wheel 10 bolt rear end - $150
And all the other stuff:
suburban barn door strap. $2+shipping
evap core in good shape. $20+shipping
700r4 torque converter cover $2+shipping
Jarhead79
Mt Vernon il
Michael
Looking for the plug end that goes to the a/c compressor. Anyone have it laying around or in a parts truck? Going to look for a new one at work but thought id ask anyhow.
yevgenievich
Viktor
sad
very sad
less sad
I should have one from an 85 harness. I can check sat or sun in what shape the connector is. Also have one from a 90, but prefer to keep that harness in one piece.
yevgenievich
Viktor
sad
very sad
less sad
It is beat up, but $0.50+shipping if you want it
Jarhead79
Mt Vernon il
Michael
I found an alternator plug at Oreillys that I used for right now so it's not needed. Appreciate you looking and finding! If I change my mind I'll let you know.
CRM
Pasco, Washington
Casey
K2500
350 CI
Are the blue front seat belts 3 point, and would they fit a 77 C10?
Tranz Zam
MA
Ryan
LM7 5.3
I'm looking for a good engine harness. I have a 78 dash harness, but I think they'll all plug into it except the 73-6ish trucks or diesels.
Let me know if you got one!
yevgenievich
Viktor
sad
very sad
less sad
Seatbelts are different between trucks and suburbans a bit.
For engine harness, I have one, but it is from a tbi truck
haywire
