squaredeal91
- Mar 10, 2023
- Cave junction Oregon
- Greg bush
- 1991 SB
- K30
- 5.9 Cummins 12 valve
Hey all, I'm working on a friend's 93 land landcrusher lol and they have owned it for years and has had a parasitic draw for a year or 2 now. Has newer AGM battery. In the past I've done some checking on it and it seems like the draw it had for keep alive items was acceptable however the battery would no longer start it if sat for 4 or 5 days approximately. Is it possible for a door open dome light switch could malfunction from moisture and cause a draw without turning on the light? It has the stupid toyota security system that is always using power but again hasn't been an issue in past years so something has changed. I want to test the battery away from vehicle to see if it drops on its own. Has aftermarket stereo and amp in it.
Any suggestions on what kinda results I should be seeing when testing battery after sitting for 12 or 24 hours? Maybe I should have the fancy Napa tester at it? Otherwise I'm going to be watching it with a multimeter to see if it has inconsistencies.
I'm a member on one of the Toyota sites and could have asked on there so Maybe im Barking up the wrong tree but I much prefer to stay on here with my people lol.
Thanks for looking.
Thanks for looking.
