ORD Swaybar quick disconnect kit...
8T6K5
AZ
L98 350 TPI
OK, been awhile since Ive really done anything to the truck. One of my biggest complaints has been its handling, especially at freeway speeds. Ive replaced the U/L ball joints-tire rod ends-drag link-steering arm-repacked bearrings-ORD steering box brace-ORD front shackles-calipers-balanced tires and Im still not happy.
Ill be replacing the setting box tomorrow and having a hd polyurathane rag joint put in as well. Hopefully that will help, or its onward up to the steering shaft.
In the meantime I added ORD's swaybay quick disconnect kit.
Drivers side OE
Pass side OE
ORD kit...pretty stout as with everything else Ive gotten from them
Drivers side with kit...
Again Drive side..... note the pin has to go in from the inside.
Pass side... again, pin in from outside (same way bolts go in).
Pass side again. Notice the bracket on top of the bump stop. Remove both pins, rotate the swaybar up and use a pin to lock it into the bracket. Wheel on.
Install was simple. Just need a 1 1/8" socket/box end to remove two bolts then install the new supplied bolts. Takes less that 30min - that includes taking pics :)
I also ordered new bushings all around which added a few minutes to the job. Just need two 11/16" sockets/wrenches to remove 4 nuts/bolts. BTW, they were a PITA to do, top two mainly, just hard to get at. Added about another 30-45min.
Basically this kit rasies the swaybar up about 2". Probably wont help much on a stock vehicle, but repositioning the swaybar on a lifted vehicle seems to be appropiate.
First impressions: simple install and I definately feel an improvement in handling and ride quality. Im very satisfied.
Next up, long travel shocks using the F-250 mounts :)
Nice work! :grd:
Oldswrench
Kernersville, NC
Mark
72 and 89
Blazer
You should check this out maybe that will help!
http://www.gmsquarebody.com/forum/showthread.php?t=1812
But specifically what is the problem that you are experiencing with the way your truck handles? Is it pulling one way or the other, or is it unresponsive, or darty in the way in handles at hiway speeds? What is maybe someone can shed some light on it.
Mark
8T6K5
AZ
L98 350 TPI
Mark
Ive read that thread quite a few times. Definately something Im looking into. Matter of fact the XJ shaft came up in another forum and I used a few of those pics, of course citing the source.
1) The steering box is toast. Spews fluid and is out of adjustment. I know I could rebuild it, but its actually easier for me just to replace it. Local company here http://www.benchworksteering.com/index.htm will be helping me and they claim to have a HD rag joint as well. I dont expect much of an issue after that, but if so I will have worked my way up the the steering shaft/column.
The problem isnt nearly what it used to be, but the only way I can describe it; is that is has a tendency to wander. If your not actively steering the slightest imperfection in the road will cause it to pull away.
When I was uploading the pics from today I actually found something that I think is suspect. Shims under the front springs, look to be 2* I think. I suspect those shims are making my front tires wobble like a shopping cart.
Im sure somebody put them in when the put the lift on to keep the drive line angle correct. But because I dont use 4WD a lot or at high speeds, they are unnecessary, IMHO.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Yea i would say it has the caster off.
The BDS springs on my Burb came with shims on them, I left them there. It handles the road fine at all speeds.
8T6K5
AZ
L98 350 TPI
What size springs - tires -front axle?
Oldswrench
Kernersville, NC
Mark
72 and 89
Blazer
Maybe you need some more caster which would help the driveline problem as well.
They are 4 inch springs, the shims have the pinion pointed up. It's an 8-lug 10 bolt axle running 305/70/16's load range 'E' and usually running 50lbs on the road.
8T6K5
AZ
L98 350 TPI
When speaking with the guy that helped install the steering gear box today, older guy, sounds like he's been around awhile, shop and rigs on the lot indicated he knew his stuff....
...he said Rancho started that years ago on the pre '78 trucks? Prior to the NP205/208 at least. With out the shims guys were having their NP203s wearring out way too fast. According to him the shims are needed for the full-time 4WD rigs and really optional on the PT. By optional he means unless your running your rig in 4WD all the time. Something about the caster......
Might help. Figure if im gonna half to drop the u-bolts to remove/adjust them, Im just going to pull them out and put in some ORD 1" zero rate blocks/leaves.
jake26104
