ORD Sway Bar Quick Disconnect Installed.
SquareRoot
Finally. Got around to installing this ORD kit. Install was a snap. Fit like a glove. Easy peasy.
Stand by for ride quality and off road performance review.
Dutch Rutter
Independence, Or
Joshua
Looks great! I ended up flipping the L "hold bracket" upwards for a little more space when disconnected, but thats probably not needed for higher lifts.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You're not done yet. Need longer shocks for more droooop.
Craig 85
Nashville, TN
454/TH-400/NP205
I installed that on my K30 and my previous truck, '79 K15. Both had Tuff Country front springs; the K30 has 3" HD's and the K15 4" EZ Rides. It's hard to tell the ride difference on the K30 I believe due to the HD springs. The K15 was the best riding Square body I've owned.
I believe the the end links help the ride of the truck. I always thought it was odd that GM would lock in the position of the sway bar. Granted on a stock truck the front end doesn't move too much. With a lift, I'm sure the sway bars and springs are moving in different arcs. This gets rid of the bind.
SquareRoot
Someone stole my K20 and left a much smoother riding square in its place! Ok seriously, I left the swaybar disconnected for the distant future and there's a noticable improvement in ride quality on the street. Actually, I'm quite surprised how much better it rides. Thinking about leaving it disconnected unless I plan to haul something substantial, which is rare.
Kipps5000
