- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
when i buy green concentrate i buy from farm an fleet 40 dollars for like 6 or so I cant remember exactI don't know if it has an incompatibility with gas engines, it is probably just that it is WAY overkill for almost every gas engine rig I can think of. It is stupid expensive and just isn't really necessary for a gas rig. The reason I know about it was as a replacement for the 6.0L powerstroke coolant that liked to gel up and clog up the coolant passages in the EGR and oil cooler. The Cat coolant supposedly had better resistance to cavitation in the coolant passages around the cylinder walls and wouldn't separate or Gel. Since there are basically CAT dealers everywhere, it's easy to go in and get some... but again it's about double the price of comparable light duty automotive coolant. I think when I got mine, it was about $20-30 per gallon of concentrate and I needed three gallons of the concentrate for the F-250. I can get a gallon of Prestone green extended life concentrate from Wal-mart for like $8
i also liked to have a case of premix on hand so I could fill a gallon of concentrate distilled and then top most of with a cheater jug
