Oil Exploded All Over Engine Bay
dangonzo
Connecticutt
Daniel
Hey Everyone,
I noticed a thick cloud of exhaust smoke behind me while driving and when I parked and checked it out I saw that oil had exploded all over the passenger side of the engine bay. There's no oil on the driver side of the engine bay, and as you can see in the picture there's quite a bit of white smoke coming from the exhaust manifold. What could this be and what should my first steps be to figure out the culprit?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Clean it up. Check engine oil level. Top off if necessary. Start engine. Use your observation skills to determine where the oil is coming from.
Most likely loose valve cover.
You're lucky it didn't burn down.
MrMarty51
Eastern Montana
Martin
Oil pressure sending unit ? this will empty the oil real fast, within a minute.
Is there an aftermarket OP gauge that is tube fed ?
Other wise, clean it all up real good with some solvent or BBQ lighter fuel{same stuff} then warsh it down good with soap and water, dry it off real good, fire up the engine, if it is leaking ral bad, shut off engine then look for leaks.
if it is leaking not so bad, check where the leaks is coming from whilst the engine is running.
May have blowed a rocker cover gasket on that side too.
dangonzo
Connecticutt
Daniel
While cleaning up the engine bay today I noticed that the fluid was actually transmission fluid. I've seen some things that point to a clogged vent tube so I'm gonna try to see what I can see.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
You're lucky you caught it. Trans fluid is flammable and many a nice vehicle have been converted to ashes from trans fluid leaks on a hot exhaust.
flying2275
United States
Jay
I'd check the transmission cooler lines going into the radiator. They run along the passenger side of the engine bay on the frame and connect to the radiator above the coolant recovery tank. It may be a pin hole leak so you'd have start up the truck to find it. Make sure to add transmission fluid prior to this.
I agree, those cooler lines should be highly suspect.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Not if they got blood all over their hands, lol.
Could be pumping it out the vent.... and in that case the lines would have been faulsly accused. It could be pushing it out the dipstick tube also
True. But everytime I've had something push out the vent, it ends up under the truck.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Hey a side note to OP ATF is an awsome degreaser. Gotta grow a positive in every once in a while to offset a negative. Keeps you sane.
michaelmarine53
