NV4500 clunk
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Hey. All new components including NV4500 professionally rebuilt. When the drivetrain transitions from being under load to unloaded (whether just letting off the gas or pressing the clutch) I get a clunking noise. In this video I’m driving around my driveway circle and periodically letting off the gas. That’s when the audible clunk is heard. Everything is tight and no noises like this came from anywhere with my TH400. Seems like I’ll be pulling this transmission and waiting for another...
<iframe class="rumble" width="640" height="360" src="https://rumble.com/embed/v9wv1h/?pub=axwcn" frameborder="0" allowfullscreen></iframe>
Carb'ed Vortec 350
You do have a direct connection now. If you had a gopro I bet you could find the cause of that. I have a feeling it is just a little slop in the gears. Other than that sound, it sounds like a normal manual transmission setup.
Dutch Rutter
Independence, Or
Joshua
Is it possible that there isn't enough clearance between the cab cut out and the top of the trans? Would probably make a different noise then an internal trans knock though.
Dingo is right too. You dont have the auto cushion anymore to soak up some of the harshness, if a u joint was on the verge with the auto it'll be louder with the manual.
Carb'ed Vortec 350
Just watched it again, hard to tell. You're a fine mechanic but did you make sure all the mounts were snuggled up? Is something now hitting the frame or body with a flop?
Carb'ed Vortec 350
Dingo is right too. You dont have the auto coushin anymore to soak up some of the harshness, if a u joint was on the verge with the auto it'll be louder with the manual.
That's why I mentioned gopro. It's amazing what you see with one of those mounted under a vehicle.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I’ve had several vehicles with a manual trans and it sounds a bit unnerving.
I looked at that even though it didn’t sound like contact with the floor and I don’t see any witness marks.
all mounts are brand new and snug...
I talked to advance Adapters and they think it sounds like excess backlash. Pretty sure that’s what they said, but that’s just from my description. They didn’t see the video.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I’ll check the floor again, but it sounds internal. How much clearance between the shift tower and the floor should there be? 1/4”?
I should mention that when I filled the trans, it leaked from not PTO covers, so I had to drain and seal it back up. Maybe the rebuilder was having an off day.
I don’t have a go pro, wish I did sometimes.
Carb'ed Vortec 350
Backlash, slop. I agree, a manual shouldn't make that noise. That's why I asked if something may be loose or flopping. You can get refurbished gopros on ebay for a decent price, and then acquire some clamp style mount and you see all kinds of neat stuff going on under the vehicle.
Dutch Rutter
Independence, Or
Joshua
It does sound quite backlash like. But if it we're mine I'd hate to tear it all back apart and find something else to be the problem after all that work.
My 700r4 had a VERY similar sound which went away after it was replaced. Thinking that was a missing internal pin at the rear of the trans (no idea the actual name of the part).
Even took it to a few shops who came up with all kinds of things, from rear gear lash, to TC, to lash in the trans output and TC input shafts, basically alot of shotgun diagnosing.
Do you happen to have an old cellphone in a drawer that can record video? If so tape that SOB under there.
Carb'ed Vortec 350
I don’t know about that, seems I have more will than skill. My willingness is strong though.
That's what matters, and being thorough, which you are. But even the great ones miss something once in a while.
Dutch Rutter
Independence, Or
Joshua
I think your right about it being internal. If it just was one "clunk" kind of sound I'd think something rocking into something else. But that kind of "ker-clunk" sound... I'd be pulling it back down, somethings not right.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I agree. The company I bought it from said to drive it 10-15 miles and see, but that’s a scary idea. They said they would send me another one. I’m going to call again tomorrow. I’ll put on my lift springs this weekend so I have at least a little sense of accomplishment.
Drive it a whole bunch and work it hard to see what happens. If it gets real bad, just tell them it happened in 10-15 miles.
JOD26
