NP 208-700r4...what gasket do i need??
adamv7010
nc
adam
k10 silverado, k10 suburban
gasket needed is for the area in red
the gasket that goes between the 700r4 adapter and the t-case itself...it has 6 bolt holes...i need it but couldn't find it in any book or on the computer @ NAPA today...
does anyone know what its called or where it can be ordered separately from an entire rebuild or gasket kit?
Thanks in advanced
i guess it would go between the input on the t-case and the adapter?
I've just seen RTV used there.
heavyleft
Fayetteville, NC
V10/K5
350ci
^^what he said. I dont recall a gasket there when I swapped my tranny. Im pretty sure I used RTV.
oneluckypops
Sedalia, Mo.
Luke
there is a gasket made for it, dont know what the part number is. Only time i seen it was a few timesive had 1 in the rebuild kit.
But as mentioned. RTV Black is what i always use. just put a bead around the adapter then smeart it all in with your finger
adamv7010
nc
adam
thanks guys...
after a little more digging i found these...
http://www.quad4x4.com/GM Transfer Case.htm
i'm pretty sure the second listed gasket is the one i was referring to...
as far as I can find...they are the only place that sells it...
83K5Blzr
michigan
Robert
350 HO
700R4 Adapter to NP208 transfer case - gasket: P/N 331304B (GM)
Makco Transmission Parts: $ 1.46
adamv7010
nc
adam
83k5..I just saw that page about an hour before I logged on here ...what'd the difference between that gasket ans the 331304A...it says various ...does that mean its all possible gaskets to go between the trans and t case?
Did you find it on the macko website or a third party? On the macko site it lists for 2.46
12turnda
