So i FINALLY had some time go work on the tank! The spare tire brace has to be removed as well as the rear frame brace. The back of the tank lines up with frame where my finger is pointing. This location puts the filler in the correct spot between bed braces. The No-Limit 4 link has a heafty brace added above the axle,so frame flex should bot be a problem.
