new to me burb!!
bens52310
Northern Minnesota
Ben
Might scrap it, she's rough! 88 1/2 ton 2wd. 152k, some pwr accs, pretty much bought it for doors and wiring but may get it runnin. Fuel pump wire is shorted to ground, mice have taken over! O well at the very least I can part and scrap it, only paid $300, can't go wrong there! I do miss my 91 waldoch burb tho...rusty but trusty!
Yeah, good buy for 300 for sure.
I'd probably give it a shot at getting it driving and roadworthy... but if it comes to it, watcha doing with the rally wheels? And also, is that a Corn Pro trailer?
bens52310
Northern Minnesota
Ben
It is a corn pro lol. 5 lug Talley wheels are useless in Minnesota so I'd probly toss em lol
bens52310
Northern Minnesota
Ben
Anybody find a common spot where fuel pump wires running on the back of the engine for the ops and pump relay short to ground? Must be right on the back of the head or somewhere where it got close to exhaust. Unplugged fuel pump, fuse blows, unplug ops, fuse blows, unplug relay fuse blows, unplug ecm, fuse does not blow. I understand power runs THRU the ecm to get to either relay or ops therefore Im gonna check between ecm and open, namely back of engine and by exhaust. Jw if someone had physically ever found a rubbed/burnt wire here to make my job 1000x easier lol. I'm sure that's where it is, ill let you know. BTW the fuse that's blowing is ecmb. I know from my experience 2 weeks ago what's on the circuit!
Guardian
Jeff
c 10
Check the oil pressure switch. Probably melted at the rear of block.
bens52310
Northern Minnesota
Ben
Ill be all over back there in a couple hrs, last resort is to run a temporary hot wire right to the dam pump! Just wanna hear it run
Tazdar
