Norwester
- Jul 3, 2015
- Battle Ground, WA
- David
- C-10
So! I decided to upgrade the headlight harness on my '86 with single headlights as they looked pretty dim to me. Now, I'm not much of a mechanic and the electrical system is pretty much voodoo to me but the kit from LMC looked pretty easy and emphasized no cutting or splicing.
The kit came and I spent a few minutes at my bench, adding some wire loom to dress it up a bit. Bought some new shiny stainless sheet metal screws for the two ground points and for the relays.
Mounted the relays near the radiator, tacked down the grounds, swapped the kit plugs for the truck's plugs, attached the two power wires to the battery, and hit the headlight switch.......NO LIGHTS! Well, I have parking lights but I assume they are on another circuit.
Now I am 99.9999% sure I mounted the kit correctly as it was very straight forward and the skimpy instructions were clear enough.
I reattached the truck's harness just to make sure I didn't blow a fuse and the lights worked fine. Now I'm not sure how to diagnose the problem.
Do folks have problems with the LMC kit being wired improperly?
Any ideas how to diagnose?
As always, thanks in advance
