New guy with Audio and Custom fab
GunMan9
Yorktown
Brandon
How do you know when you have sufficient layers of cloth?
J_sleezy
Pine Bluff AR
K10 Scottsdale
It gets more rigid with each layer. When you think it's sturdy enough it's most good to go.
GunMan9
Yorktown
Brandon
I have decided to just buy a new dash pad lol It sounds like to much work and with my time and supplies it would cost just as much to buy a new dash pad
J_sleezy
Pine Bluff AR
K10 Scottsdale
Got a little more done. I got the amp and crossovers mounted.
J_sleezy
Pine Bluff AR
K10 Scottsdale
notverrysmart
washington
EJ
suburban
Is there a reason why your running your amp bridged or is that just the picture?
Great work so far man, keep up the good work!
J_sleezy
Pine Bluff AR
K10 Scottsdale
Ahahaha glad you noticed it! I didn't even pay attention to it.
This is probably a really stupid comment by me so bear with me and correct me if I'm wrong but I thought you wanted to run your amp bridge when possible for more output and more sound. Is that wrong?
J_sleezy
Pine Bluff AR
K10 Scottsdale
NVM that'll the correct wiring for the front stage.
@Old77 It really depends on what your speakers can handle. In my case my amp supplies more than enough power non-bridged for my JBL components, but the channels for my sub will definitely be bridged to supply the most power at a 4 ohm load.
:waytogo: That makes sense! I was thinking of it powering the subs but I can see why you'd want it non-bridged for the components.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
not all amps can handle being bridged. even if they can its not always worth it. distortion is raised and you only gain 3 db (which happens when power is doubled). i guess its worth it if you are an spl guy. i enjoy music not test tones but thats just me. admittedly the added distortion isnt necessarily audible but it does add stress/heat and can decrease the longevity of the amp.
J_sleezy
Pine Bluff AR
K10 Scottsdale
Right! And this is more of a SQ setup. The whole SPL thing got old in my jeep. Ill be doing a 3 way active setup when $$$ permits.
J_sleezy
Pine Bluff AR
K10 Scottsdale
Hell I guess I could show the truck lol forgot that part!
And this is my other toy :)
notverrysmart
washington
EJ
suburban
How does it correct the wiring for the front stage? Wouldn't that make it mono?
All of my setups have been for balanced audio, not for competition style audio so forgive me if I'm thinking wrong.
J_sleezy
Pine Bluff AR
K10 Scottsdale
No your right lol I had an idiot moment :Stupid Me: The way it is in the picture one crossover is actually bridged. I fixed it tho.
Obullard74
