New from Texas
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
350runner let me know about this place so here I am. Currently have an 89 K5 blazer, and recently sold an 82 SW with 383 and an 86 SW. Wouldn't mind finding another one. I also have a couple of 72 Buicks to go fast in.
350runner
tx
Ceasar
Hey Mark have y'all done much with the K5?
MadOgre
NA
NA
NA
NA
NA
Welcome! I like quadjets too. Do you know where a guy guy can get back cutting reamers for the throttle shaft bores for a reasonable price ?
Skweegle89
Oklahoma
Hey Mark. Carb is running top notch. Had a couple problems getting it to idle but I with a couple adjustments, I think I have the bugs worked out.
Stewzer55
Ohio
Stew
R30
:welcome: from Ohio!
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Thanks everybody for the welcomes.
350runner, I bought the truck in all original tired condition. So I replaced all the suspension components, steering and brakes. 4 inch all spring lift, and added the tires using stock wheels. Engine/trans still remain stock at this point.
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Not for reasonable price really. I use a special cut drill bit and set the depth. It has worked well for years, and I use it on every Quadrajet I build. Check with cliffshighperformance.com I don't think he list his bits on the site, but I do think he has them available to purchase. Cliff has good quality parts.
Dadof2
Central Texas
R1500 Chevy Sub, C20
350 in both trucks
Howdy from Central Texas.
MadOgre
NA
NA
NA
NA
NA
Im looking for the reamers though. Thanx
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
so you are wanting to make the primary bores larger? Not sure what your looking for here. I was talking about cutting the shaft bore.
MadOgre
NA
NA
NA
NA
NA
NO. Im looking for back cutting reamers for the throttle shaft bores.
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
Here is what I use. It's the cut drill bit I referred to earlier. I cut the bore, and install bronze bushing on every build.
:welcome: from N.E.
85Shortsquare
