New clutch won't depress!!
C0dy
Central mass
Cody
1979ish
Custom deluxe
Put in a new clutch when I rebuilt my tranny got it all back together and now the pedal won't depress, seems like everything in the pedal assembly is fine (as it was before) but the fork holding the throwout bearing seems like it doesn't want to push the pressure plate?? It just won't push it in... Now I feel stupid I was sure I put everything together right ..maybe the wrong clutch?? (asked for stock replacement from advanced auto but never heard of the brand) any thing I should check before I rip this thing back out :banghead:
Most of the truck is a 79 chevy k20/ sm465 with mechanical clutch linkage:banghead:
roadtriper
Maine
Bob
K10 SWB
Cody, when you re-assembled everything did you have to make any drastic changes in the clutch linkage like something had changed or parts weren't the same?
the throwout bearing needs to slide smoothly on the trans input collar, drop the linkage between the bellcrank and the Throwout arm. see if you can move the throwout back and forth on the input collar? maybe pull the boot back and have a peek in there to see if the lever is over the pivot correctly
the other thing that comes to mind... is the clutch disc installed the correct way? the bulky side of the disk where the springs protrude needs to be towards the relief in the Pressure Plate. if the Throwout bearing assembly isn't cocked on the input collar or something like that, it sounds like you are coming back apart :-( Bob
scottybaccus
Central Texas
Scotty
GMC R1500
That's a good indication that the clutch disc is in backwards.
roadtriper
Maine
Bob
K10 SWB
Cody, what did you find???
Pugs Speed Shop
