Need help with 465 clutch adjustment
Disco
Texarkana, TX
C10 "Big 10"
350 4-bolt
With the clutch all the way to the floor and the adjuster rod on the fork nearly all the way out, the trans scratches 1st (low?) and reverse. Nothing I do seems to fix it. There seems to be plenty of spring tension on the fork, and it doesn’t have much play. What am I doing wrong?
The shop manual recommends trimming the rubber pedal stop under the dash to 3/8”, but I can barely find that with probing fingers, much less see it or figure out how to remove it to perform said modification.
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
did you put the clutch plate in correctly?
Disco
Texarkana, TX
C10 "Big 10"
350 4-bolt
I‘ve not had the clutch out. This is a revival. I just got it started today, and I’m trying to get it to move now.
According to the neighbor I bought it from, it was running and driving before the fork return spring broke and he parked it. That was 2007.
Disco
Texarkana, TX
C10 "Big 10"
350 4-bolt
Ok, it caught reverse, but with the clutch pedal all the way to the floor and the parking brake on, it started backing down the drive, then stalled…
WebMonkey
Missouri Ozarks
L and R will almost always grind.
(especially if you're moving already or have a 'high' idle)
they are UNsynchronized.
1,2,3 ARE synchronized.
good luck
Disco
Texarkana, TX
C10 "Big 10"
350 4-bolt
Alright. I’ll try 1st tomorrow. From how it behaved, reversing with the clutch in and the brake set, kinda sounds like my clutch is dragging or not fully disengaging.
Ontheboulder
colville,wa
greg
Well now it’s making sense! Sounds like the pressure plate is sticking and maybe has some broken springs. Sitting since 2007 hasn’t done any good
Disco
Texarkana, TX
C10 "Big 10"
350 4-bolt
Eww… I was afraid of that. Ok, so clutch job… I can’t do that on my back under the truck with simple hand tools and no special equipment (like an engine hoist), I assume?
Disco
Texarkana, TX
C10 "Big 10"
350 4-bolt
Anyone know which clutch goes in a Big 10 350 456? I have 4 options here:
-An 11” clutch disc with normal finger spring diaphragm
-A 12” disc with the same
-An 11” disc with what appears to be a coil spring diaphragm
-A 12” disc with the same.
Alex123
