Need Help on Wheel Studs
hillbillywillis
Arkansas
Karen
Did a drum brake conversion on my 85 and the original 15" wheels will no longer fit, so we ordered new wheels and now the wheel studs are too short. Having a heck of a time finding new ones that are longer. Has anyone had this issue? I have ordered several sets from Summit and both are wrong. The first was the correct length but the width was too small -- ended up being wheel studs for a chevy s10. The next set were the correct length we needed, but are too big to fit into the axle. They sent us one for a Ford Mustang. Any ideas on what we need? It shouldn't be this hard. I went to a local wheel shop and they weren't any help. It's my first build so I am not very knowledgeable. THanks in advance.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
What kind of wheels did you order? If you got alloys, you should more than likely be using a shank style lugnut. If steel, shouldnt have any problems with the same old acorn nuts.
highdesertrange
kalifornia
mike
k30
have you contacted the people you got the conversion from. my guess is you are trying to put aluminum wheels on? do you have the correct lug nuts for the rims? highdesertranger
hillbillywillis
Arkansas
Karen
The new wheels are alloy but the problem is that when we put on the conversion kit for the disc brakes the new wheel studs are too short to fit through everything. I'm going to go today and see if any local shops can get us fixed up. It's frustrating to order online and then find out it doesn't fit.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
If all else fails, try a wheel spacer.
highdesertrange
kalifornia
mike
k30
maybe I didn't explain it right. the conversion kit should have came with studs. did it? then the alloys should have come with the proper lug nuts, did they? some alloy's take special lug nuts and when you place the wheel on the studs it appears there is not enough stud but in fact with the proper nuts there is. highdesertranger
jturner
