need a new radiator
kgc4160
wahington
kelly
i need a new radiator.. tried to have my old one rebuilt.. shop said not worth it.. so any recommendations on a new one.. would like a direct fit and not have to modify anything.. 81 with a 305/auto..
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Are the end tanks still good?
If so, it can be recored. I got quoted 400 to make mine a 4 core, and will - one of these days. :D
I wound up buying a plastic and aluminium one in the interim.
Cheaper, they work, and mine fit well but I am an all metal fan.
Can't find the dam things , though.
Wonder if radiator barn is still around online ?
:think:
Good luck!
Britt
I bought a 3 row Champion aluminum radiator from Jegs and it was a direct fit for my K25. It looks like they are still priced at about $250.
With this radiator I've had my truck idling in about 90 degree weather for nearly an hour while I recharged the A/C, and it never got above about 195 degrees with a 195 degree high flow thermostat. In normal driving it runs about 185-190 degrees (measured with aftermarket mechanical gauge), so apparently the thermostat opens a little early.
I also have a Robert Shaw stage one high flow water pump, stock steel fan, and HD fan clutch.
Jppr26
Deer island
V20 custom deluxe
I got a new HD aluminum radiator from orelies for $140 last year
4WDKC
Southern Florida
Kacy
keep an eye open at swap meets, I bought a 31" alum 2 core radiator for $100, to use in an old truck. It wouldn't fit the gmt400 platform so its in my garage.
Nonstop
Ca
Nick
K2500
I have Champion Radiators in 2 of my cars and they are great! Customer service was good, and my cars run a lot cooler. When the time comes, I will likely put one in my truck, although the idea of being able to run to O’Reilly to get a replacement is tempting if there is a warranty problem.
Camar068
10 yrs Air Force
aaron06
