My trailer Build!
John-e Bravada
Oregon IL
C30 3+3
5.9L CTD
An old FF rear axle. I have a D70 with a missing carrier. Cut the center out if you need it narrower. Brakes would be tough.
John81287
Mchenry,IL
V20
Doesn't need brakes. Just axle hubs and tires! Keeping it simple
John81287
Mchenry,IL
V20
Does it have the leafs?
John-e Bravada
Oregon IL
C30 3+3
5.9L CTD
No but I have the set off my CC, you could mix and match leafs to get the load capacity you want. It's a SRW D70 out of a 91' Dodge. You could use any FF I just have this one in my scrap pile because someone pulled the carrier and threw away the bearing caps so the center section is useless without the correct caps. That and I don't like Dana axles, I'm a 14bolt guy.
John81287
Mchenry,IL
V20
What do ya have to have for that and a set of leaf springs?
John81287
Mchenry,IL
V20
Are you going to have it around for a bit? I'd like to think about the best option. Going to see how it pulls and acts before I jump into spending anymore money on it.
John-e Bravada
Oregon IL
C30 3+3
5.9L CTD
It will be here awhile. Keep us posted on how it pulls.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
early 90's dodge caravan. axle unbolts with springs and perches and make the best trailer axles. plus tires are easy to find for them
John81287
Mchenry,IL
V20
I will keep that in mind thanks guys! I'm gonna give it a test run this upcoming Monday. So we will see after that.
So I got my trailer all done! Come to find out this lovely state I live in now requires a state police inspection on ALL home made trailers. I wish like hell I could leave this state. Pics to come when I get home " endrant"
Oh boy I missed this part. :popcorn:
Posted From Hell
John81287
Mchenry,IL
V20
You keep eating your popcorn over there I'm hopefully getting it figured out the Tuesday after Labor Day!
Driver4r
Nebraska
Trevor
k10,c20
Alot of minivans run an offset rearend where the axle is not direct to the back of the hub and is offset, We found a Nissan Quest(murcury Voyager) Is a PERFECT trailer axle.
John-e Bravada
Oregon IL
C30 3+3
5.9L CTD
Yeah I had to go thru that when I built my car hauler. Its a pain! Iowa was allot easier.
12turnda
