Much to do...
Go stepside or not?
  • Do it!
    Votes: 2 25.0%
  • Leave it.
    Votes: 6 75.0%
  • Total voters
    8
Don R
Kansas
Don
JIMMY
Most older vehicle frames in Kansas are too rusty to read any numbers. Lol trust me, I spend a lot of time under them.
SchontheBeast
California
Schon
GMC
Update: VIN swap is actually not going to be difficult. CHP does a light/brake inspection and will assign a new VIN according to the year of the frame (says my CHP friend). Everything currently works, so that shouldn't be a problem with new cab.
Now, for the wipers, will I just need to replace the '85 posts with my originals to fit under the '73 hood? Also, I know the '85 glass is thinner. Will it still work in my '73 doors? I like the old doors better than the new, so I'm curious.
SchontheBeast
California
Schon
GMC
Replacing transmission currently. Was the 9" tail shaft standard on stock short bed half tons with a TH350 or is mine unusual?
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Different truck, but I hate power windows so I swapped to 78 burban doors, my 88 burban windows were tinted, so I swapped em. New seals should take up any wiggle, mine Seemed to fit fine. Don't know if that helps at all, but thought I would tell you.
73c20jim
Tombstone, AZ
Remember to match the window frame gaskets to the thickness of the glass.
K201979
Winona, missouri
Hippie
350ci
Welcome from Missouri. I say go stepside if you found a good one, at a good price.
1973c10
Don
:welcome:
ceyman72
