MANUAL to AUTOMATIC conversion
mr heavy-chevy
WA state
fox
its a 1987 so it has the computer and the neutral safety switch.
i may do the pedal swap, or just remove the clutch pedal by itself...
so far i know i will need:
transmission ( 700R4 )
torque converter
flex plate
shifter ( probably a cable floor shifter)
TV cable
transmission cooler & lines
who has done this before and can recommend some parts?
thank you! :cheers:
mr heavy-chevy
WA state
fox
has no one done this before?
i need some input
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I'd do a pedal swap. The hydraulic clutch setup (pedals, master and slave cyls) is worth $300 and will help offset the cost of the conversion.
ctonton
