manual hub conversion problems
4WDKC
Southern Florida
Kacy
Anyone ever have issues putting the manual hub back in the hub itself? These parts.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
No, but make sure to push the axle shaft forward from the back. Sometimes they slide and your can't install the retaining clip.
highdesertrange
kalifornia
mike
k30
what's the problem exactly? they came out, right? highdesertranger
4WDKC
Southern Florida
Kacy
No it was a full time 4wd axle that I cleaned up and added new ball joints axle u joint, then converted to manual hubs. Problem appears to be because the spindle was turn forcing axle to be not on center.
highdesertrange
kalifornia
mike
k30
the axle should have a little slop in it. you should be able to move the stub axle around. you should start the hub on axle then move the rotor as you push the hub in. highdesertranger
Ls85c10man
