Manifolds or headers
The88
Mhmm
South Louisiana
ThatGuy
Or you can do manifolds and just send the headers to me.... just sayin for another option
MikeB
North Texas
Everyone complains about header gaskets, I've never had an issue.
Same here. I typically use FelPro gaskets with a steel core (like the 1444), and then re-tighten the bolts after a few hours run-time. And if I remember to do it, I check them every year or so, but rarely have I turned one more than 1/8 turn. I recently used some round Mr. Gasket steel core gaskets to seal GM Vortec heads and Patriot 1-5/8" tube headers. No issues with them either after 5 months.
For collector flanges I like to use soft aluminum gaskets. I've used the Summit brand at least three times with zero issues, and they are reusable.
Gasket problems are caused by using a cheap gasket or a gasket that doesn't properly seal the machined surfaces around the perimeter of the head ports and header ports. When working on customer cars, it's not uncommon to find a gasket/ header flange combination that seals less than 1/8" of the machined surfaces around the ports. Even if it's just one small spot, that's a leak waiting to happen. Sometimes, there's not much you can do about it, especially with cheap headers and 1/4" flanges with ports that don't line up well with the head ports.
hirschdalechevy
norcal
rich
k-30
Headers all the way on my square's , doug thorley tri y's and hedman elite's. Here is the hedmans on my blazer , nice fit.
77scottsdale1
Scipio Indiana
michael
k20
It was in the cab of my truck when I was cleaning it.
Chype1
