Manifolds or headers
77scottsdale1
Scipio Indiana
michael
k20
My engine I bought Saturday has manifolds on it, should I keep them or should I get a set of headers?
The88
Mhmm
South Louisiana
ThatGuy
The real question is what are you doing with the truck and do you like changing gaskets?
Swims350
Logan WV
none
be more like what exhaust does it have now and are you willing to change it?
everyone complains about header gaskets, I've never had an issue I use stock fel pro exhaust manifold gaskets up top, they are alum. on one side and paper on the other. I never had issues and they are cheap to replace if you need to.
Down low I opt for ball end collectors or get a set of summit header buddies for flat flange style headers they use no gasket. I know some say they have issues with those, I never have. Some chop the collectors off the headers and weld pipes directly to them.
I only hate manifolds because they warp or crack, the studs break and area pain to remove or replace in the collectors. So I usually buy headers.
If you have a set that's good and has good studs down low that you can reuse, I'd use em. If not then you can pick up headers for around 120 new. black painted, which never lasts lol.
77scottsdale1
Scipio Indiana
michael
k20
It won't be to hard to change the gaskets I don't think, but I haven't had a chance to look at the manifolds to see if they're cracked yet. I have a set of headers in the shed just I was wondering if it would increase hp
The88
Mhmm
South Louisiana
ThatGuy
Well if you got the headers I would go for it. Just as long as they fit accordingly. I fig you were asking if you should get some instead of running the manifolds.
As for more power what have you got on the in coming side? If you want more air to come out you have to have more going in as well if that makes much sense.
Swims350
Logan WV
none
exactly right couldn't agree more if you got em run em. I don't think they could hurt, might raise underhood temps, but I think they flow better and I like em. If it come down to buying new headers if the manifolds are good run em, but since you have headers, I'd run headers.
74 Shortbed
If the headers are in good shape and fit, I'd run them..
77scottsdale1
Scipio Indiana
michael
k20
I haven't checked if they're in good shape or not, I haven't seen em in 5 years. They're just in the back of the shed and the shed is packed with other truck parts
77scottsdale1
Scipio Indiana
michael
k20
I would also just be running a k and n filter.
74 Shortbed
Well preserved then, lol..
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
The factory squarebody manifolds aren't great for flow lol. I have a set of ramhorn manifolds I'm gonna throw on to the motor I'm putting in, one of the best flowing cast manifolds known to man haha
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I'm looking to swap to long tube headers in the future for my k10. Cracked one of the manifolds into three separate chunks and I'm pretty sure the other one is cracked somewhere as well.
If you've got em, why not dig em out and give em a fit to see?
Headers tend to help free up a little power and torque due to the better flow rate. Faster you can get it in and out, the more power you'll be making.
88SQDRW
