Made an accessory fuse block
semperfiguy98
Camas, WA
Michael
Suburban K20
Hey all. I made an accessory fuse block and mounting bracket. (OK I didn't make the fuse block, but I did the layout and insert the connector receptacles). It has circuits for CB/Ham radio, front/rear LEDs, and power taps for phone/device charging. The wiring came from work. I just used some Deutsch connectors for the ends. Then I made the mounting assembly from some scrap. We have a brake, so bending was fairly easy. Then welded the feet to it. I'll send more pics once I install it.
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
Looks pretty sweet, would love to see it installed.
KilgoreTrout
Pennsylvania
Dylan
350ci
Yeah, it looks good.
Sent from my moto g(7) play using Tapatalk
Camar068
10 yrs Air Force
Looks great. What model box and pins are those? You should think about making fuse boxes for LS swaps. With all those slots, you could put a fuse on every ckt and still have room for tons of relays.....including daytime running lights etc.
semperfiguy98
Camas, WA
Michael
Suburban K20
This is the datasheet for the box. We got a bunch of them from a vendor to use as samples. Our electrical engineers said they had some spares and I could take them if I wanted. I actually have a few from different brands because vendors are always bringing us stuff to test.
https://www.waytekwire.com/datasheet/45989.pdf
I'm not sure if that link works, but you could probably copy and paste into your browser.
The pins are Metripack 280 style pins. The ones we have are open barrel, and they require a specific crimper for that. The Deutsch connectors on the end also require a specific crimper, but we stock those here at work since the equipment that we manufacture uses them.
MikeB
North Texas
How did you power it?
semperfiguy98
Camas, WA
Michael
Suburban K20
The larger Deutsch connector has 2 12 guage wires that supply power to most of the circuits. I'm pulling power from the junction block on the firewall. I'm making a harness from that to supply the fusebox and then from the box to the accessories that it powers. When it's done, I'll post some more pics. I'm also working on building a complete harness for my son's Camaro.
MikeB
North Texas
Have you thought about feeding the junction block with a larger wire, or is it currently fed by two 10 ga (metric equivalent) wires?
adhkjashda
