Long tube headers/dual exhaust question
87SQRBDY
Fayetteville, NC
Josh
5.7l 350
I just had long tube headers and 2 1/2" dual exhaust put on my 87R10, but I wanted to know if I should put an H pipe on it or just leave it? An X pipe would be a lot more work. Would it be any better or the same leaving it as is or not. Thank you.
Camar068
10 yrs Air Force
have read H pipe right behind the x-fer case is the perfect spot.
Rusty Nail
Rusty
350sbc
H pipe is /wincity.
Your truck will "level up" for.sure. and you may kick yourself for not doing it sooner because it sounds F- AWESOME!
*This is the 2.25" system in my '88 Blazer 4x4.
ChuckN
Bellinham, WA
Chad
I thought I remembered Engine Masters doing an episode on this stuff, if the performance aspect matters to ya.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I actually prefer the sound of a dual exhaust small block with a little bit of cam and no H pipe.
I have no valuable input in regards to power or efficiency of either set up. Allegedly a properly placed H or X scavenges better
Donald
Loris SC.
Don
GMC 1500
Unless you are out for total performance I think an X or H pipe would be a waste of time.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I love my h- pipe. The only truck I may not do it to is my grandpas truck since I want it to be like the good old days.
But personally i hate the small block popcorn. Especially 90's chevys. Straight pipe 90's Chevys makes me wanna ****** puke lol. With full length exhaust that is. Ear piercing blap blap blap blap. Sounds like their boyfriends ******** in a tunnel. The h-pipe really cleans up the exhaust noise and makes a small block sound mean with full exhaust. Even dumped before the rear tires, a stock motor with h-pipe doesn't sound like a turd.
Also its super easy to install.
87SQRBDY
Fayetteville, NC
Josh
5.7l 350
Thank you to all that responded and apologies for just now thanking y'all. I will def check out the engine masters show as well as take eveyones advice on the matter.
WesN
Edmonton Alberta Canada
Wes
C1500
I was experiencing horrible drone at 30 mph so installed the crossover. Mellowed just enough to kill the drone and enjoy cruising around town. I made it so it will come apart so one side or the other can be removed without fighting with both.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
H pipe will give a very small performance increase. not worth it IMHO.
MikeB
North Texas
I've installed an H-pipe on one vehicle, and an X-pipe on another. Have to say I didn't notice much difference in sound or seat-of-the-pants performance. But it stands to reason that back pressure will be somewhat reduced with two paths for an exhaust pulse to follow.
I didn't watch the Engine Masters video above, but those guys are mostly concerned about peak horsepower at high RPMs, and sometimes get all giddy if an engine makes another 5 hp after some modification. Every once in a while they do mention the torque curve and drivability, but not very often.
darrel
