Locker and 13 bolt shave install.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I hope every time either of you go through a real deep puddle you remember to check your diff fluid.
That's how funny you two sound.
I never check or change my differential fluid unless it's leaking or I have a reason to go in there.
My post was related to some comments about the cut-down ring gears failing which some suggested was from the removal of material and I thought it may have more to do with people driving their uber-manly rock crawlers on the highway 99-94/100% of the time with an aftermarket diff cover. Because, you know, that tin cover the factory put on isn't studly enough to be seen past the truck nuts.
If you actually watched the videos you'd see that slow speed off road isn't an issue and an aftermarket cover may have it's benefits, but if you intend to drive to and from Moab at highway speeds that's where they fall down and probably fry your bearings or gears.
But by all means, carry on as you see fit. I wasn't trying to insult your maintenance schedule or your engineering.
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
I can find no corroborating evidence to the cracked ring gear theory.
Notice all 14 bolt covers look darn near stock, even after market.
I am thieving other peoples engineering.
I will carry on, and be the first to tell you all if I crack a ring gear dailying/bashing a shaved 14 bolt, or have any other issues.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I thought 78 and I were the young bucks around here...lol!
At least after honky scared the other ones away.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Trailer queens(that are not purpose built) are just as bad as a squatted no sidewall P.O.S.(My opinion)
Yes that is just YOUR opinion. And MY opinion is that you are correct. :happy160:
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I look at that like I should only ride dual sports, because towing my motocross bike is lame. Which is silly.
The really purpose built stuff isn’t always street legal.
I think it’s all cool if people are having fun with stuff they’ve earned. I respect it all.
rpcraft
Robert
LS 6.0 364 CID
all above mentioned is correct.
if you take your truck offroad with a 14 bolt, you will quickly realize your diff gets hung up on everything it can find. I have read zero reports of damages diff cases from either shaving or 13 bolt conversions. ORD runs shaved and 13 bolt kits and I bet the run harder than us.
its not for everyone I guess....but it makes damn good sense to do if you wheel it all.
This is true but then again I have never read of a damaged Diff case from dragging it over everything. I jthink I would just prefer to add lockers to both axles and more power
77 K20
Montana
K20 5" lift
HT383 fuel injected
I drive my truck from and to the trails. And most of the time I just cruise at around 60- truck seems to like it and I've never had any issues.
But several years ago a trail took me longer than I thought and I had to haul butt back home to pick up my kid from school. So I did an hour of highway driving at 70-75 mph. Screaming along at 3500 RPM made it in time. But when I got out of my truck I smelled oil- my 14 bolt rear diff puked its fluid out of the vent hose attached onto the underside of the bed. Differential was very hot. It has never done this again- but I haven't driven that fast. In fact I drove it to my parents a few weeks ago with a load of firewood on the highway. It's 2.5 hours by highway (at 60 mph) to get there.
Why? Was it the aftermarket thick cover?
Was it the fact that my exhaust dumps before the axle and maybe all that exhaust was heating it up?
Don't know.
legopnuematic
Licensed Junk Dealer
MO
Spencer
reisman20
